AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Water Does Not Stop/hose Disconnected To Pressure Switch
The hose has come off the to the pressure switch and not able to gain access to the back. The panel is too low and unable to reapply the clamp on the hose. I am afraid to break anything and can't figure how to take it apart to gain access to the back. The small panel is too low. Any suggestions. Please help. Thank you.
you should be able to access the water level switch by removing the rear panel on the control console. Be sure to blow through that tube before reconnecting it. Probably vibrated loose. This machine is a bear when it is spinning anyway.
Washer Repair
