JANEY2008
#1 Posted : Monday, May 12, 2008 7:37:08 PM(UTC)
JANEY2008
The hose has come off the to the pressure switch and not able to gain access to the back. The panel is too low and unable to reapply the clamp on the hose. I am afraid to break anything and can't figure how to take it apart to gain access to the back. The small panel is too low. Any suggestions. Please help. Thank you.
SublimeMasterJW
#2 Posted : Tuesday, May 13, 2008 4:53:22 AM(UTC)
SublimeMasterJW
you should be able to access the water level switch by removing the rear panel on the control console. Be sure to blow through that tube before reconnecting it. Probably vibrated loose. This machine is a bear when it is spinning anyway.
