gerardjuarez
#1 Posted : Monday, May 12, 2008 9:47:30 AM(UTC)
gerardjuarez
Hello,
I tested what I believe to be the thermal fuse on the top of the long metal tube of my dryer (i was getting no heat and my timer was not working). I set my ohm meter to 200Ω and got a reading of .1 or so. I also tested the lower fuse on the same metal tube and it was 9.2 with the meter set at 200Ω. I am basically looking for the correct fuse to buy and where to buy it. Thanks!
-GJ
glen65
#2 Posted : Monday, May 12, 2008 5:58:56 PM(UTC)
glen65
I'm not yet convinced you need one “at least not yet”.
I’m not quite sure why you are getting 9 ohms
that’s about the resistance you would normally see
at the element itself. Are you going directly across
the two terminals of the stat itself?
