Jay V
#1 Posted : Monday, May 12, 2008 6:48:11 AM(UTC)
Jay V
hi my range started acting up f1 f3 codes. unpluged and replace pulg worked good for a while. oven would light get to temp then not re-light. ingniter comes back on no gas. i replace oven vavle and circut board. didnt fix oven wont start unless tap vavle. you can blow out top burners like blowing out candles. it is like not enough gas?
SublimeMasterJW
#2 Posted : Tuesday, May 13, 2008 6:53:04 AM(UTC)
SublimeMasterJW
If your ignitor is mellow orange it may be bad. It should be as bright as the sun. Your oven sensor's quick plug could be contaminated with corrosion or grease. Clean it real good and retry.I bet the whole problem was a weak ignitor.APP-meters-circuit-tester.gif
SublimeMasterJW attached the following image(s):
Viking gas range oven troubleshooting (Oven Repair (including Ranges and Cooktops))
by MK_ 3/3/2024 10:10:13 AM(UTC)
Kitchenaid Gas Range KGRA806PSS00 (Oven Repair (including Ranges and Cooktops))
by bobr55 2/16/2024 1:31:09 PM(UTC)
Stuck bottom pan on gas range (Oven Repair (including Ranges and Cooktops))
by Guest 11/4/2023 12:02:07 PM(UTC)
Whirlpool Gas Range No Lights and Locked Door After Self-Clean (Oven Repair (including Ranges and Cooktops))
by Guest 2/20/2023 8:05:39 PM(UTC)
Gas Range Electrolux parts (Appliance Parts)
by becky97060 12/13/2022 11:07:33 AM(UTC)
Capri Gas Range Door won't close tightly (Oven Repair (including Ranges and Cooktops))
by Guest 5/26/2022 9:56:34 AM(UTC)
Maytag CRG7500AAW Gas Range (1995) access to spark module (Oven Repair (including Ranges and Cooktops))
by videobruce 4/10/2022 4:14:27 AM(UTC)
GE XL44 Gas Range - Oven Turns On by Itself (Oven Repair (including Ranges and Cooktops))
by keywiz77 2/27/2022 9:32:21 AM(UTC)
Gas Range - all four burners spark continuously if any one burner is lit (Oven Repair (including Ranges and Cooktops))
by eichsel 1/29/2022 7:48:44 AM(UTC)
Gas Range Burners Won't Stop Sparking (Oven Repair (including Ranges and Cooktops))
by eb5 12/7/2021 12:05:37 PM(UTC)
Samsung NX60T8711SS smart dial gas range (Oven Repair (including Ranges and Cooktops))
by bob4al 11/10/2021 2:16:51 AM(UTC)
Amana gas range turns off while baking (Oven Repair (including Ranges and Cooktops))
by Shhomemom 10/18/2021 2:11:00 PM(UTC)
Jenn-Air Cook Top Gas Range JGC1526ADS15 (Oven Repair (including Ranges and Cooktops))
by patelvi 9/15/2021 1:11:05 PM(UTC)
GCRG3060AFC Frigidaire Gas Range Timer & Temp Display Error (Oven Repair (including Ranges and Cooktops))
by ChuckCastiglione 8/22/2021 7:09:15 PM(UTC)
Fisher Paykel Gas Range - Issues with broil burner (Oven Repair (including Ranges and Cooktops))
by extrafu 7/23/2021 6:44:10 AM(UTC)
