Hey Folks, hoping you can help. I have a Kenmore HE3T front load washer that seems to work fine, EXCEPT that the tub fills with water between uses. It must be a slow leak, because I don't notice it unless we don't do laundry for a week or so. If it hasn't been used in a week, I see that the tub is full of water, but not high enough to leak out of the open door. Any thoughts on what I should do to fix this?
Thanks Tim
Hi Tim,
Most likely the problem is a bad water inlet valve. If you need the correct part number, post the complete model number of the washer.
