tballard
#1 Posted : Friday, February 19, 2010 8:24:32 AM(UTC)
tballard
Hey Folks, hoping you can help. I have a Kenmore HE3T front load washer that seems to work fine, EXCEPT that the tub fills with water between uses. It must be a slow leak, because I don't notice it unless we don't do laundry for a week or so. If it hasn't been used in a week, I see that the tub is full of water, but not high enough to leak out of the open door. Any thoughts on what I should do to fix this?
Tim
#2 Posted : Friday, February 19, 2010 5:33:23 PM(UTC)
Hi Tim,
Most likely the problem is a bad water inlet valve. If you need the correct part number, post the complete model number of the washer.
washer fills with water when off (Dishwasher Repair)
by hidon 5/27/2010 8:16:55 AM(UTC)
Front load washer fills with water when off (Washer Repair)
by volunteer2 3/5/2010 11:57:52 AM(UTC)
Washer fills with water when OFF (Washer Repair)
by tballard 2/19/2010 8:25:50 AM(UTC)
