krfarre
#1 Posted : Friday, May 9, 2008 8:14:34 PM(UTC)
krfarre
Hello all
Just a querie in regards to an E3 error message that I have got on my MAYTAG dishwasher. Has anyone got an idea on what that means short of getting an overpriced tradie in?
#2 Posted : Saturday, May 10, 2008 4:18:10 PM(UTC)
The model number you posted does not come up. Is it American model?
competitions
#3 Posted : Sunday, February 15, 2009 2:39:06 PM(UTC)
competitions
Hi
I experienced the same E3 error some weeks back. I called the repair man and a circuit board was replaced. All has been well until today when it did the E3 again. Hopefully it was a one off error, if not I'll be looking for competition to the original repair firm used.
I have the manual and the error details are as follows -
E1
Cause: Water supply switched off.
Remedy: Switch off appliance. Turn on water supply. Reset the cycle.
E2
Cause: Problem with electronic temperature control.
Remedy: Call service for assistance.
E3
Cause: The water heater element does not work properly or the filter mesh is blocked.
Remedy: Clean the filter mesh and if the problem continues please contact service
E4
Cause: The appliance does not discharge water.
Remedy: Check that the discharge hose is not bent, syphon is not blocked, filters are not blocked.
Hope that helps!
