herman stoehr
#1 Posted : Wednesday, February 17, 2010 11:41:20 AM(UTC)
herman stoehr
I have a dishwasher that works just fine, however with no power on the base fills with water it doesnt do it all the time. I beleive the fill valve is leaking by. your thoughts please. thanks Herman
magician59
#2 Posted : Wednesday, February 17, 2010 12:32:22 PM(UTC)
magician59
The fill valve is solenoid-controlled. If the valve gets fouled, it won't completely close. You may need to replace it if there is no way to clean it. Check your water for hardness.
herman stoehr
#3 Posted : Thursday, February 18, 2010 10:53:59 AM(UTC)
herman stoehr
Thanks so much I thought this might be the problem.
