rmything
#1 Posted : Thursday, May 8, 2008 5:32:26 PM(UTC)
rmything
:eek: I just got a used dishwasher from my brother and I hooked everything up and tried to use it but when the water started going in to the washer it started to come out of a white plastic tube that says do not touch check valve. Do I need to replace this peice or is there another problem? Any help would be appreciated. Thanks
#2 Posted : Friday, May 9, 2008 2:06:36 PM(UTC)
Did you connect the drain hose to this "white plastic tube"?
What is the complete model number of the dishwasher?
rmything
#3 Posted : Sunday, May 11, 2008 4:41:29 PM(UTC)
rmything
No I didn,t connect the drain hose to this part. Was I supposed to? The model # is DU912PFGQ1. Thanks for the reply
#4 Posted : Sunday, May 11, 2008 10:38:46 PM(UTC)
How did you connect the drain hose?
rmything
#5 Posted : Tuesday, May 13, 2008 2:19:53 PM(UTC)
rmything
I connected it to a barbed nipple that comes out of the bottom. Was I supposed to connect it to the check valve?
#6 Posted : Tuesday, May 13, 2008 3:15:13 PM(UTC)
You can find everything in the installation instructions.
