How do hook my block term back up to my dryer??????
Vague question. you mean to the pigtail(cord)simple, middle wire to middle outer wires to outer terminal. the dryer usually has a white wire from the harness that goes to the middle(neutral) red to one side for heating and black to the other side for motor. For a 4 wire cord just hook red and black to the sides and white in the middle. hook the green wire to the ground. PSS and GSS refrigerators service manual.pdf (1,717kb) downloaded 85 time(s).SublimeMasterJW attached the following image(s):
