hsmith
#1 Posted : Tuesday, February 16, 2010 7:01:46 AM(UTC)
hsmith
I need to change both the freezer and the refridgerator gaskets but I do not see any screws to remove the gaskets. How do I remove and replace the gaskets?
magician59
#2 Posted : Tuesday, February 16, 2010 12:15:48 PM(UTC)
magician59
Some of the new gaskets just press into place; Others have screws hiden under the outer lipof the seal.
hsmith
#3 Posted : Tuesday, February 16, 2010 12:18:50 PM(UTC)
hsmith
I looked and there are no screws. I appears to be pasted in and I am not sure what adhesive to use.
magician59
#4 Posted : Wednesday, February 17, 2010 12:12:35 PM(UTC)
magician59
If any adhesive is needed, it will probably be included in the package with the replacement seal.
