I need to change both the freezer and the refridgerator gaskets but I do not see any screws to remove the gaskets. How do I remove and replace the gaskets?
Some of the new gaskets just press into place; Others have screws hiden under the outer lipof the seal.
I looked and there are no screws. I appears to be pasted in and I am not sure what adhesive to use.
If any adhesive is needed, it will probably be included in the package with the replacement seal.
