:confused: I need a wiring Diagram or some help. The compressor will not come on unless I bypass the board and then it works fine. I need to test the components to see what is wrong. any suggestions?
How did you bypass the board?
You may have referred to my sticky above, GE refrigerator (GS $ PS) models. You probably have a bad motherboard AP4436216. Remove the board in the back of the fridg, and check the solder connections near the power relay, just might need re-soldering.
Originally Posted by: Gene  How did you bypass the board?
Gene. I jumped from line to comp on the card to see if the compressor would run. And cooled the refrigerator back down.
Originally Posted by: Bama55  I jumped from line to comp on the card to see if the compressor would run. And cooled the refrigerator back down. Sounds like the problem is a bad main control board and you might be able to fix it follow the richappy advice. Gene.
