Bama55
#1 Posted : Monday, February 15, 2010 3:03:27 PM(UTC)
Bama55
:confused: I need a wiring Diagram or some help. The compressor will not come on unless I bypass the board and then it works fine. I need to test the components to see what is wrong. any suggestions?
#2 Posted : Monday, February 15, 2010 4:53:57 PM(UTC)
How did you bypass the board?
#3 Posted : Tuesday, February 16, 2010 2:40:57 AM(UTC)
You may have referred to my sticky above, GE refrigerator (GS $ PS) models.
You probably have a bad motherboard AP4436216. Remove the board in the back of the fridg, and check the solder connections near the power relay, just might need re-soldering.
Bama55
#4 Posted : Tuesday, February 16, 2010 6:48:58 AM(UTC)
Bama55
I jumped from line to comp on the card to see if the compressor would run. And cooled the refrigerator back down.
#5 Posted : Tuesday, February 16, 2010 8:08:52 PM(UTC)
Sounds like the problem is a bad main control board and you might be able to fix it follow the richappy advice.
