captain1
#1 Posted : Monday, February 15, 2010 6:19:43 AM(UTC)
captain1
My control board is lite up but when I hit start nothing happens???? I think it needs a new control panel but could it be something else???
#2 Posted : Monday, February 15, 2010 10:14:39 PM(UTC)
Replacement parts for MAYTAG MDE5500AYW Dryer - Ele | AppliancePartsPros.com
Here is a service manual
http://www.servicematters.com/maytag_library/docs/16023110.pdf
[COLOR="Blue"]My control board is lite up but when I hit start nothing happens???? I think it needs a new control panel but could it be something else???[/COLOR]
Yes, could be a thermal fuse is blown.
Take a look at the wiring diagram Page 10-2, you will see two thermal fuses in line with the motor.
Unplug the unit and check them with a meter, both should be 0 ohms.
If it is the one on the blower is blown Item 10 in Section 5 be sure to clean/check your vent system as this is the most common cause of it blowing.
If it is the one on the heater assembly is blown Item 11 in Section 4 then you have to find out what caused it to go.
Note: that sometimes they do just blow on their own but changing it without checking other things is a gamble.
Check the heating coil.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run on high and the thermostats cannot regulate it.
If the above is OK then you will also have to replace the hi-limit Item 8 in Section 4 as it should have regulated the temperature so the fuse did not blow.
You still have to find out why it blew.
Check the seal (drum etc) in the unit. The air is pulled over the heating coils, through the drum and pushed out the exhaust. So any large seal leak will pull in room air and the cycling thermostat on the blower will run the unit hot.
Check that the lint filter is not coated with fabric softener residue which greatly reduces air flow.
Check/clean your vent system.
Check/clean the blower wheel.
If all OK you may want to replace the cycling thermostat as it's contacts may not be opening (welded shut).
Also check that the door switch contacts are closing.
s moore
#3 Posted : Tuesday, January 4, 2011 10:46:02 AM(UTC)
s moore
WE have the same model.......a 8.8 code comes on....and dryer won't start. We were told we need a new control board.
Looking to tune up our Maytag Neptune Dryer (Dryer Repair)
by bassett72 2/14/2018 4:51:00 AM(UTC)
Neptune Dryer Flickering Lights (Dryer Repair)
by Harrisej25 9/27/2015 10:58:53 AM(UTC)
Neptune dryer will not start-fuses and door switch works (Dryer Repair)
by Maryland1 1/10/2015 12:02:30 PM(UTC)
by 3pinballs 9/10/2014 11:33:08 AM(UTC)
how to take apart front face of maytag neptune dryer to get to coils (Dryer Repair)
by m218perez 6/18/2014 12:25:10 PM(UTC)
Maytag Neptune Dryer LOUD High Pitch Screeching (Dryer Repair)
by audioarch 2/28/2014 3:53:13 PM(UTC)
Small Paint Brush Stuck in Maytag Neptune Dryer Lint Trap (Dryer Repair)
by PVBSJ 11/20/2013 5:57:47 PM(UTC)
Maytag Neptune Dryer Doesn't Start on /off (Dryer Repair)
by torrealtl1 11/13/2013 9:39:51 AM(UTC)
Maytag Neptune Dryer doesn't work (Dryer Repair)
by pulsar2121 11/3/2013 3:41:03 PM(UTC)
maytag neptune dryer issues (Dryer Repair)
by blueovalfever 10/14/2013 6:25:43 AM(UTC)
Cleaned Neptune Dryer and now nothing. (Dryer Repair)
by micitylady 8/26/2013 11:00:23 AM(UTC)
Maytag Neptune Dryer wont do anything (Dryer Repair)
by heg0423 8/21/2013 10:26:37 PM(UTC)
Neptune dryer (Dryer Repair)
by syne1s 4/25/2013 9:30:14 PM(UTC)
Maytag Neptune Dryer not starting (Dryer Repair)
by buckeye597 2/17/2013 4:09:06 PM(UTC)
Need Service Repair Manual Maytag Neptune Dryer MDE4000AYW (Dryer Repair)
by Paul02 8/12/2012 2:21:22 PM(UTC)
