Kamamaste
#1 Posted : Tuesday, May 6, 2008 7:25:43 PM(UTC)
Kamamaste
Excessive grinding/growling noise during spin cycle. Escalates as the rpms increase. Sounds like a bad bearing. Machine is approx 18 months old. Any suggestions?
#2 Posted : Wednesday, May 7, 2008 2:31:22 AM(UTC)
I would pull off the outer cabinet and look at the tub seal above the tranny, if it's leaking, this would confirm bad bearings/seals. This is rather rare, unless the washer is really old.
Kamamaste
#3 Posted : Wednesday, May 7, 2008 8:51:47 AM(UTC)
Kamamaste
The machine is only 18 months old. Have you heard many issues with this particular model? (Whirlpool Duet Sport Front-Loader WFW8300SW)
#4 Posted : Wednesday, May 7, 2008 12:52:46 PM(UTC)
I didn't know it was a front loader. If you failed to use the special soap, you may have ruined the spin bearings.
Kamamaste
#5 Posted : Wednesday, May 7, 2008 3:06:34 PM(UTC)
Kamamaste
We have used the recommended soap (HD) from the beginning. Is there a repair manual/prints/drawings/part list available for this model? If the spin bearing is bad, is this a difficult repair? I am a Machinist by trade and rebuild autos as a hobby.
gearhead1218
#6 Posted : Wednesday, May 7, 2008 5:35:41 PM(UTC)
gearhead1218
If the machine is only 18 moths old, you should be able to get warranty coverage if the rear bearing is bad.
