AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Hotpoint clothes washer cold water is just trickling in
When washer is on cold/cold temp, the water barely trickles in. When it is on warm/cold, the water is very hot and then during the cold rinse is barely trickling in.
its possible the screen filter on the cold water hose is clogged, remove hose completley and check . check in side watervalve also/ if all looks clear ,replace water valve +hoses
Washer Repair
