Sarah Gray
#1 Posted : Monday, May 5, 2008 1:42:04 PM(UTC)
Sarah Gray
When washer is on cold/cold temp, the water barely trickles in. When it is on warm/cold, the water is very hot and then during the cold rinse is barely trickling in.
misterfixall
#2 Posted : Monday, May 5, 2008 2:24:29 PM(UTC)
misterfixall
its possible the screen filter on the cold water hose is clogged, remove hose completley and check . check in side watervalve also/ if all looks clear ,replace water valve +hoses
Guest (4)
