what is a thermal limiter, if it is tripped can it be reset, where is it located??? any help would be appreciated:)
A thermal limiter, aka thermal fuse (#36 on the break down diagram) is not resettable safety device. It has to be replaced if it's open. - The part number for the thermal limiter is AP2108182 Here are the break down diagrams for the Frigidaire dryer Model GLET1041AS1Gene.
