savage1964
#1 Posted : Monday, May 5, 2008 1:05:39 PM(UTC)
savage1964
what is a thermal limiter, if it is tripped can it be reset, where is it located??? any help would be appreciated:)
#2 Posted : Monday, May 5, 2008 5:34:36 PM(UTC)
A thermal limiter, aka thermal fuse (#36 on the break down diagram) is not resettable safety device. It has to be replaced if it's open.
- The part number for the thermal limiter is AP2108182
Here are the break down diagrams for the Frigidaire dryer Model GLET1041AS1
Electrolux Dryer Outlet Thermal Limiter keeps failing (Dryer Repair)
by gawhaler 11/26/2014 5:49:42 AM(UTC)
Thermal Limiter (Dryer Repair)
by laabsdan 12/6/2011 12:50:53 PM(UTC)
Dryer Heat On Then Off (element,thermostat, or thermal limiter?) (Dryer Repair)
by KJW 11/21/2010 10:54:47 PM(UTC)
Thermal Limiter Help (Dryer Repair)
by Zankou 10/8/2010 6:27:32 AM(UTC)
Where do I find my Thermal Limiter? (Dryer Repair)
by Repaircaveman 5/13/2010 2:29:28 AM(UTC)
how to test Thermal limiter (Dryer Repair)
by pcalnc 5/26/2009 5:14:00 PM(UTC)
by kitv 11/21/2008 5:08:26 PM(UTC)
kenmore laundry center thermal limiter (Dryer Repair)
by sunshine5500 1/15/2008 10:58:11 AM(UTC)
