sls
#1 Posted : Monday, May 5, 2008 9:00:46 AM(UTC)
sls
Can someone explain how to repair my GE dryer belt? I have taken the top and lower back screws out and cleaned and removed all of the dust, but I cannot find a way to get to the drum wheel to put the new belt on. There was also an L shaped rod I could see from the lower rear of the dryer and a black wheel on the floor of the dryer that was probably attached to the rod before the old belt broke. I could not find a bolt (even in the vacuum dust bag that kept it on), although I did find a metal washer, so there must be one in there somewhere. Thanks for your assistance.
#2 Posted : Monday, May 5, 2008 5:05:16 PM(UTC)
You have to remove the front panel, the rear access panel and the drum.
- The part number for the belt is AP2619947
replace dryer belt (Dryer Repair)
by angeloserra 8/5/2011 7:56:43 AM(UTC)
How to replace dryer belt on MDE9206AYW (Dryer Repair)
by qtlee 1/30/2011 9:38:51 AM(UTC)
I need to replace dryer belt (Dryer Repair)
by awwpoooy 9/20/2009 5:56:20 AM(UTC)
by Barbara Krul 9/14/2009 8:21:31 AM(UTC)
by Jack Hunsicker 3/11/2009 10:58:50 AM(UTC)
need to know how to replace dryer belt/with photos if possible (Dryer Repair)
by lindasilverlady46 6/30/2008 7:43:53 AM(UTC)
how to replace dryer belt (Dryer Repair)
by donnao 9/18/2007 1:16:12 PM(UTC)
