i need toknow how togo about replaceing the belt on my dryer
Remove the 2 screws at the lint screen opening, raise the top ,remove 2 screws inside of the front panel at the top,remove the front panel, clean up the inside of the dryer, put the belt on and reassemble!!!:)
Originally Posted by: Drags1998  Remove the 2 screws at the lint screen opening, raise the top ,remove 2 screws inside of the front panel at the top,remove the front panel, clean up the inside of the dryer, put the belt on and reassemble!!!:) Thanks u just saved me big bucks I wasn't sure how toget it apart!!!
Thankyou!! Wasn't sure how to remove the front ! A repairman was going to charge my mother $175.00 To replace the belt ! Again THANKYOU!!
WOW!!!!!!!!! Thats $95 MORE than I get to do the same job!!!!!!! I should move to where you live, I could do quite well there!!!!!!!:D :D :D
