My 'infinite temperature selector' does not seem to work. I only get high heat no matter what I set the selector on. I have checked the temperature selector with ohm meter and it seems to be working. I have checked the two thermostats(operating and hi-limit) and both have continuity. Can anyone help? thank you
How did you check the temperature selector switch? Did you check the thermostat heater (#16 on the break down diagram)? Gene.
dryer works now...replaced the operating thermostat/heater assy.
I'm glad you were able to fix it.
