asdf1855
#1 Posted : Sunday, May 4, 2008 6:44:06 PM(UTC)
asdf1855
My 'infinite temperature selector' does not seem to work. I only get high heat no matter what I set the selector on. I have checked the temperature selector with ohm meter and it seems to be working. I have checked the two thermostats(operating and hi-limit) and both have continuity.
Can anyone help?
thank you
#2 Posted : Monday, May 5, 2008 2:49:22 PM(UTC)
How did you check the temperature selector switch?
Did you check the thermostat heater (#16 on the break down diagram)?
asdf1855
#3 Posted : Monday, May 26, 2008 2:09:07 PM(UTC)
asdf1855
dryer works now...replaced the operating thermostat/heater assy.
#4 Posted : Monday, May 26, 2008 7:34:02 PM(UTC)
I'm glad you were able to fix it.
