JEROME BRYSON
#1 Posted : Wednesday, February 10, 2010 12:25:59 PM(UTC)
JEROME BRYSON
Washer won't agitate nor spin.
sidfink43
#2 Posted : Friday, February 12, 2010 6:15:57 AM(UTC)
sidfink43
Take off the front and see if the belt is ok. If it is, see if the transmission will turn freely and if the motor is getting power. Also check the pump to see if something is jammed.
This should diagnose your problem.
Frigidaire Washer Dryer Combo Not Working (Washer Repair)
by soshea42 7/10/2016 4:10:09 PM(UTC)
Frigidaire washer dispenser magnet (Washer Repair)
by JAbraham 1/19/2016 12:05:33 PM(UTC)
Frigidaire washer won't agitate (Washer Repair)
by goosemasterkl 8/15/2015 9:37:13 AM(UTC)
Frigidaire Washer - No agitation and no spin (Washer Repair)
by jmplsjones 6/29/2015 7:30:44 AM(UTC)
Frigidaire Washer error code 31 (Washer Repair)
by tilegods 5/1/2015 4:15:19 AM(UTC)
Frigidaire Washer will not spin (Washer Repair)
by luvmylars 4/30/2015 11:33:25 AM(UTC)
Frigidaire washer - loud screeching noise at start of spin cycle (Washer Repair)
by Shrimpzilla 4/8/2015 10:25:33 AM(UTC)
Frigidaire Washer "Unique" Leak? (Washer Repair)
by randynavarro 1/3/2015 7:11:35 AM(UTC)
frigidaire washer turns on by itself and floods floor (Washer Repair)
by justin r 12/31/2014 12:32:12 PM(UTC)
Frigidaire Washer Wont spin high speed (Washer Repair)
by jchi2210 12/17/2014 12:01:09 PM(UTC)
Frigidaire washer won't do much ... (Washer Repair)
by leahthrash@gmail.com 10/8/2014 8:10:24 AM(UTC)
Frigidaire Washer (Washer Repair)
by michelle400 8/20/2014 12:45:15 PM(UTC)
affinity frigidaire washer (Washer Repair)
by kc5tf 6/17/2014 7:29:02 AM(UTC)
Frigidaire Washer has water sitting in the bottom (Washer Repair)
by Brian84 6/14/2014 1:48:02 PM(UTC)
by MarkShannon 5/11/2014 6:02:41 AM(UTC)
