abrzrkr
#1 Posted : Friday, May 2, 2008 10:34:34 AM(UTC)
abrzrkr
I replaced the water inlet valve and cleaned the float mechanism inside the tub. I disconected the float switch and held the wires together and it still will not fill. When I replaced the water inlet valve I tested the water supply line and it is live. Does any one have any ideas? Thanks for your help.
Seth
abrzrkr
#2 Posted : Friday, May 2, 2008 1:11:12 PM(UTC)
abrzrkr
Anyone have any clue what the problem could be? I'm at a loss here.:confused:
misterfixall
#3 Posted : Friday, May 2, 2008 7:28:56 PM(UTC)
misterfixall
is there water coming to valve from water supply
abrzrkr
#4 Posted : Saturday, May 3, 2008 6:17:23 AM(UTC)
abrzrkr
Yes there is water at the fill valve. Is there a brain or a computer that would prevent the fill valve from doing it's job?
misterfixall
#5 Posted : Saturday, May 3, 2008 6:57:35 AM(UTC)
misterfixall
if your not getting 110 volts to float switch it well maybe control board .p.s is d/w doing anything ,any sign of life ,sounds ,lights,etc
abrzrkr
#6 Posted : Saturday, May 3, 2008 9:28:40 PM(UTC)
abrzrkr
The machine starts and there is noise and action but no water. Could that be a malfunction with the control panel?
misterfixall
#7 Posted : Sunday, May 4, 2008 2:54:41 AM(UTC)
misterfixall
are you getting 110 volts to float switch? if not it sound like board ,check to see power from board also.if there is power . check for continuity in wire from board to fl. switch, to see there is no break in wire.
