I replaced the water inlet valve and cleaned the float mechanism inside the tub. I disconected the float switch and held the wires together and it still will not fill. When I replaced the water inlet valve I tested the water supply line and it is live. Does any one have any ideas? Thanks for your help. Seth
Anyone have any clue what the problem could be? I'm at a loss here.:confused:
is there water coming to valve from water supply
Yes there is water at the fill valve. Is there a brain or a computer that would prevent the fill valve from doing it's job?
if your not getting 110 volts to float switch it well maybe control board .p.s is d/w doing anything ,any sign of life ,sounds ,lights,etc
The machine starts and there is noise and action but no water. Could that be a malfunction with the control panel?
are you getting 110 volts to float switch? if not it sound like board ,check to see power from board also.if there is power . check for continuity in wire from board to fl. switch, to see there is no break in wire.
