jelly
#1 Posted : Wednesday, February 10, 2010 7:47:51 AM(UTC)
jelly
control pad wont unlock by doing what the instructions say to do
#2 Posted : Thursday, February 11, 2010 1:39:36 AM(UTC)
Replacement parts for MAYTAG MDBTT70AWB Dishwasher - Undercounter | AppliancePartsPros.com
Here is a tech sheet
http://www.servicematters.com/docs/wiring/TechSheets_11_17_09/Schematic%20-%20W10179503.pdf
[COLOR="Blue"]control pad wont unlock by doing what the instructions say to do[/COLOR]
Not sure what you mean by unlock?
Try unplugging/ removing power from the unit for half an hour or so to see if it will reset.
Try running the diagnostics.
Perhaps the keypad (control panel) has an open key. Try the below cleaning if that does nothing check the keys with a meter.
The usual way to troubleshoot is check the keys with a meter. If all OK then it is probably the control board.
Connector Cleaning / Checking
Unplug the unit
Open it up
Remove the ribbon cable from the keypad to the control board at the control board.
Clean the edge connector.
If it is the type where there is not a connector just the insulation is removed, it can be cleaned with a pencil eraser. Do not use an ink eraser as it is too abrasive.
Check the tracks in the ribbon cable for hairline cracks. A magnifying glass helps here.
Would not hurt to clean the connector on the board. Use electronics contact cleaner or isopropyl alcohol and a tooth brush. Be gentle and do not reconnect till all the solvent evaporates.
Reconnect everything and give it a try.
Maytag dishwasher model MDB4949SKZ1 (Dishwasher Repair)
by thepontif 2/3/2024 11:15:46 AM(UTC)
Maytag dishwasher drain always runs? (Dishwasher Repair)
by Guest 12/15/2023 6:04:35 PM(UTC)
Heating element won't turn off on Maytag dishwasher (Dishwasher Repair)
by Guest 8/2/2023 6:10:10 AM(UTC)
Maytag dishwasher not cleaning top shelf very well. (Dishwasher Repair)
by Guest 10/20/2022 10:23:08 AM(UTC)
Maytag dishwasher leak from bottom of door (Dishwasher Repair)
by Guest 7/27/2022 1:58:00 PM(UTC)
Maytag dishwasher, cancel button (Dishwasher Repair)
by jtt21 6/28/2022 5:24:58 PM(UTC)
Maytag dishwasher quiet series 300 (Dishwasher Repair)
by Guest 6/12/2022 7:04:36 PM(UTC)
Maytag Dishwasher Not Entering Installation Cycle (Dishwasher Repair)
by Sparky9680 5/16/2022 9:37:56 AM(UTC)
Maytag dishwasher MDB4709AWW1 (Dishwasher Repair)
by dkmc1953 3/6/2022 1:13:12 PM(UTC)
Maytag Dishwasher stops several times during normal cycle (Dishwasher Repair)
by vanordens3 12/28/2021 12:26:19 PM(UTC)
Maytag Dishwasher Making Clanging Noise Even When Empty (Dishwasher Repair)
by gtg931 12/20/2021 7:13:20 PM(UTC)
Maytag dishwasher leaking and smoking (Dishwasher Repair)
by Guest 10/19/2021 2:58:51 PM(UTC)
Maytag dishwasher MDB4949SDZ0 (Dishwasher Repair)
by tonygm 5/29/2021 1:47:18 PM(UTC)
Maytag Dishwasher LEAKING underneath (Dishwasher Repair)
by bakerid2000 9/5/2019 5:49:20 PM(UTC)
Maytag dishwasher fills, then drains (Dishwasher Repair)
by vtfireman85 3/12/2019 7:30:34 PM(UTC)
