Recoop
#1 Posted : Wednesday, April 30, 2008 7:52:43 PM(UTC)
Recoop
I have a problem with water leaking out front of freezer door. A large cake of ice forms in the bottom of the freezer. I am sure that the drain for auto defrost is plugged up, but I cant seem to locate it. Could you give me a hint on were the drain line is located and how to get to it.
Thank you in advance
Recoop
#2 Posted : Thursday, May 1, 2008 4:58:26 PM(UTC)
Recoop,
The drain hole is located in the freezer, under the evaporator coil. You have to remove the rear panel to access it.
Use a hair dryer to defrost it and a cup with really hot water to make sure it goes through.
Here are the break down diagrams for the Frigidaire refrigerator Model FRS22PRCD0
Label
#3 Posted : Saturday, November 21, 2009 1:45:06 PM(UTC)
Label
Waterline for leaky water disposal GE sideby side refrigerator
