I have a problem with water leaking out front of freezer door. A large cake of ice forms in the bottom of the freezer. I am sure that the drain for auto defrost is plugged up, but I cant seem to locate it. Could you give me a hint on were the drain line is located and how to get to it.
Thank you in advance
Recoop
Rank:: Advanced Member
Recoop, The drain hole is located in the freezer, under the evaporator coil. You have to remove the rear panel to access it. Use a hair dryer to defrost it and a cup with really hot water to make sure it goes through. Here are the break down diagrams for the Frigidaire refrigerator Model FRS22PRCD0Gene.
Waterline for leaky water disposal GE sideby side refrigerator
