bmagya4ever
#1 Posted : Tuesday, February 9, 2010 4:42:53 AM(UTC)
bmagya4ever
My dryer produces very little heat. A load of clothes can take a day to dry. I have replaced the thermostat and the thermostat limit. The next next step I have assumed would be to replace the thermal fuse. However, when I replaced the thermostat limit, the wires were singed. The thermostat limit I purchased from Appliance Parts Pros did not come with a new wire. The EXACT same part at a nearby Sears Service Center came with the wire. Could the problem be just the wire or the thermal fuse?
sidfink43
#2 Posted : Wednesday, February 10, 2010 6:50:51 AM(UTC)
sidfink43
Your thermal fuse will shut down the machine if it is blown, so I doubt if that is your problem.
The wire to the limit thermostat may well be a problem. check it for continuity. If there is any question about it, replace it. If you need to, talk to APP about it (we who respond here are volunteers and are not connected with the parts operations of the company) They are usually very good about any parts issues.
You also want to check to see that you are getting 120v to each side of the connection block.
If everything checks out, and your vents are clear (the most common problem with lack of heating is an obstructed vent either inside or outside the dryer) then check your heating element. You are looking for 9-10 ohms, clean wires with no breaks or sags.
Here is a Maytag tech bulletin on how to check components.
http://www.servicematters.com/m...ibrary/docs/16023127.pdf
and here is a service manual for your machine, although it sounds like you have had no trouble getting into it.
http://www.servicematters.com/m...ibrary/docs/16023020.pdf
