On my third control board. Got this one last week. the machine worked fine for a couple of days now it just stopped in the middle of a cycle and the panel lights are all dead.....had to pump the water out with a shop vac. Originally the boards failed by showing a continuous blinking light .....this time nothing. I even put the old board in to see if would still blink...nothing? What should I check now?
Cannot find any info using the given model number please check it.
Many DU units have a thermal fuse attached or on the board, perhaps this is blown. |
THIS FORUM IS DEAD!!!!!!! |
yes that was it - thanku. any insight as to what causes that thermal fuse 2 fail?
