finman
#1 Posted : Monday, February 8, 2010 6:10:41 AM(UTC)
finman
On my third control board. Got this one last week. the machine worked fine for a couple of days now it just stopped in the middle of a cycle and the panel lights are all dead.....had to pump the water out with a shop vac. Originally the boards failed by showing a continuous blinking light .....this time nothing. I even put the old board in to see if would still blink...nothing? What should I check now?
#2 Posted : Monday, February 8, 2010 7:52:16 PM(UTC)
Cannot find any info using the given model number please check it.
Many DU units have a thermal fuse attached or on the board, perhaps this is blown.
finman
#3 Posted : Tuesday, February 9, 2010 6:39:16 AM(UTC)
finman
yes that was it - thanku. any insight as to what causes that thermal fuse 2 fail?
#4 Posted : Tuesday, February 9, 2010 7:32:27 AM(UTC)
Here is info on a DU1145
Control panel parts replacement parts for WHIRLPOOL DU1145XTPB0 Undercounter Dishwasher | AppliancePartsPros.com
Take a look at Item 6 in Section 2
The harness that comes with the fuse must also be installed.
