I just had the heating element put in and it worked. Now it will not start. We have checked all areas to juice.
Here are your parts Replacement parts for rex3514rqo models | AppliancePartsPros.comHere is the wiring diagram http://www.servicematters.com/docs/wiring/Wiring%20Sheet%20-%208528187.pdf[COLOR="Blue"]We have checked all areas to juice[/COLOR] I am assuming that you have both 120 volts side and 240 between the sides. Start circuit is fairly straight forward. Does the interior light work? Also check that it shuts off when the door is closed. If OK I would check the thermal fuse in the motor circuit. This is the one on the blower assembly, Item 23 in Section 3. If blown replace it ASAP as it is a critical safety device. If the fuse is OK I would then check the door switch and the push to start switch. Also if blown be sure to clean/check your vent system, this is the most common cause of it blowing. Also clean/check the blower. |
THIS FORUM IS DEAD!!!!!!! |
