I have a GE gas dryer and when I turn it on the heat only works for a couple of minutes.
sonnyw, Most likely the problem with your dryer are a bad gas valve coils. You have to remove the front panel to gain access to the coils. - The part number for the coil kit is AP3094251 Gene.
