sonnyw
#1 Posted : Monday, April 28, 2008 6:52:08 AM(UTC)
sonnyw
I have a GE gas dryer and when I turn it on the heat only works for a couple of minutes.
#2 Posted : Tuesday, April 29, 2008 3:52:06 PM(UTC)
sonnyw,
Most likely the problem with your dryer are a bad gas valve coils.
You have to remove the front panel to gain access to the coils.
- The part number for the coil kit is AP3094251
