KRO
#1 Posted : Monday, April 28, 2008 1:27:01 AM(UTC)
KRO
I would like to check to see if the thermo fuse on my dryer is the problem that needs fixed...I have a Sperry ohm meter DM-210A but I'm not quite sure how to use it...does the power have to be on to the dryer?...and how do I set the meter to show me if this is the problem? I've double checked everything 10 times with the dryer...the timer runs, it begins to heat but when I press the on button nothing happens...checked door also and breaker box...thanks:confused:
fixtec90
#2 Posted : Monday, April 28, 2008 3:52:57 AM(UTC)
fixtec90
Rank:: Advanced Member
I can't tell you how to set your meter w/o seeing it, but you can check your t-fuse by:
Unplug dryer
Remove the wires from the t-fuse and jump them together
Make sure wires (now connected) aren't touching anything conductive (metal)
Plug dryer in and start. If the dryer starts, runs, and heats replace t-fuse.
#3 Posted : Monday, April 28, 2008 7:28:29 PM(UTC)
KRO,
In addition to fixrec90, the following article on our forum will explain in detail how to run a continuity test using either an analog meter or a digital meter – How to check continuity with Ohmmeter.
Which thermostat connectors do I test with ohm meter? (Refrigerator & Freezer Repair)
by topfreeze 12/10/2010 1:30:05 PM(UTC)
