InAZ
#1 Posted : Thursday, February 4, 2010 8:26:59 PM(UTC)
InAZ
I have the temperature selector for the freezer set to the warmest setting, but the freezer doesn't get any warmer than -35F. The fridge is set to 5 and is fine except for a chunk of frost right above the top crisper drawer.
What should I be looking at?
#2 Posted : Friday, February 5, 2010 1:50:03 AM(UTC)
Here are your parts, includes a wiring diagram
Replacement parts for MAYTAG MSD2756GEB Ref - SXS/I&W | AppliancePartsPros.com
Here is a manual
http://www.servicematters.com/maytag_library/docs/16010154.pdf
Sounds like your thermostat (Item 3 in Section 2 of the parts) is toast.
InAZ
#3 Posted : Friday, February 5, 2010 5:17:37 AM(UTC)
InAZ
Thank you SO much! Just to confirm, that would be the "control assy. temp", correct?
#4 Posted : Friday, February 5, 2010 5:36:25 AM(UTC)
Yes, that would be it.
I would check out Page 2-9 just in case it is a damper problem though the thermostat is the most likely cause.
InAZ
#5 Posted : Friday, February 5, 2010 5:53:00 AM(UTC)
InAZ
Will do! And thanks for the service manual link. Interesting reading!
