Just over a year old. Wife overloaded it. After trying to reset the motor (open and close lid) and failing, I removed the front cover and saw the old belt broken and laying on the floor. Bought belt WH01x10353 and took 6 hours putting the thing on (and turning my hands into hamburger). Now I find the motor not running. When the cycle starts, and water fills up there is complete silence. I know the motor shaft turns freely. There is NO noise, NO smoke. Is there a fuse? How do I know if there is a switch problem? (By the way...just a home owner...dont have tools to test current). What is the exact reset pattern (i could have sworn it worked before when the wife made the water too soapy.) Any suggestions?:confused:
***Jost got off the phone with local repair/supply shop that said it sounds like a wire came loose from motor or switch. Asked what type...will it need solder. He said it would be a slip on wire. Any schematics or places to look first?
*****Talked to a friend of mine that said that one of the wires acts as a fuse, and that I would have to locate that specific wire to see if it is bad. Anyone know color/location of the wire?
