Mattyt
#1 Posted : Thursday, February 4, 2010 4:55:26 AM(UTC)
Mattyt
Just over a year old. Wife overloaded it. After trying to reset the motor (open and close lid) and failing, I removed the front cover and saw the old belt broken and laying on the floor. Bought belt WH01x10353 and took 6 hours putting the thing on (and turning my hands into hamburger). Now I find the motor not running. When the cycle starts, and water fills up there is complete silence. I know the motor shaft turns freely. There is NO noise, NO smoke. Is there a fuse? How do I know if there is a switch problem? (By the way...just a home owner...dont have tools to test current). What is the exact reset pattern (i could have sworn it worked before when the wife made the water too soapy.) Any suggestions?:confused:
***Jost got off the phone with local repair/supply shop that said it sounds like a wire came loose from motor or switch. Asked what type...will it need solder. He said it would be a slip on wire. Any schematics or places to look first?
*****Talked to a friend of mine that said that one of the wires acts as a fuse, and that I would have to locate that specific wire to see if it is bad. Anyone know color/location of the wire?
Mattyt
#2 Posted : Friday, February 5, 2010 3:46:10 AM(UTC)
Mattyt
Does this: Part Details - GE Kit - fuse harness, part number: AP4380189 usually go bad? Just wondering.:confused:
Fan Motor Not Running & Partition Between Fridge & Freezer Hot. (Refrigerator & Freezer Repair)
by steve500 5/28/2017 2:40:24 PM(UTC)
Dryer Motor Not Running Click heard (Dryer Repair)
by FixHR 12/23/2016 7:19:17 AM(UTC)
Frigidaire Dishwasher won't drain, fill, motor not running (Dishwasher Repair)
by Foofer 3/3/2014 10:13:05 AM(UTC)
dryer motor not running?? help (Dryer Repair)
by robertr13 5/26/2011 1:54:36 PM(UTC)
Circulation motor not running for entire wash or rinse cycles (Dishwasher Repair)
by jmcgrath52 1/4/2011 12:08:47 PM(UTC)
motor not running (Refrigerator & Freezer Repair)
by metrolvmc 12/2/2010 10:38:20 AM(UTC)
"Motor not running properly" (Washer Repair)
by jjnemoiii 8/7/2010 3:26:19 PM(UTC)
Dryer motor not running but heat is (Dryer Repair)
by macadoow 10/25/2009 4:46:02 PM(UTC)
