rdelaune
#1 Posted : Wednesday, February 3, 2010 12:25:24 PM(UTC)
rdelaune
The frig was cooling to about 60 degrees at the lowest, before I disconnected the Diffuser. Once disconnected, I pryed the passageway open (inside the diffuser). Since then the frig is cools great. This is a temp fix though - does anyone know if the problem may be the Diffuser, or thermostat or something else?
#2 Posted : Thursday, February 4, 2010 12:15:24 AM(UTC)
Replacement parts for WHIRLPOOL KSRS27ILSS01 | AppliancePartsPros.com
Here is a tech sheet
http://www.servicematters.com/docs/wiring/Wiring%20Sheet%20-%202216445.pdf
And a manual with a pretty good section on the damper.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/3432afb789c2e7c085256ab00061f90c/$FILE/4317324.pdf
Run the diagnostics first.
If OK
Check the air baffle switch and motor
If OK
Check the thermistor with a meter
If OK
Then it could be the control board is shot.
