AppliancePartsPros.com
Appliance Repair Help
Refrigerator & Freezer Repair
KitchenAid - Frig cooling only when Diffuser unplugged - Any Suggestions?
The frig was cooling to about 60 degrees at the lowest, before I disconnected the Diffuser. Once disconnected, I pryed the passageway open (inside the diffuser). Since then the frig is cools great. This is a temp fix though - does anyone know if the problem may be the Diffuser, or thermostat or something else?
THIS FORUM IS DEAD!!!!!!! |
