MRELLIS12
#1 Posted : Monday, April 21, 2008 9:43:37 PM(UTC)
MRELLIS12
MAYTAG WASHER WILL NOT START. IT WILL SPIN OUT WATER .BUT WILL NOT FILL WITH WATER . MAKES HUMMING NOISE WHEN YOU PULL OUT KNOB.:confused:
#2 Posted : Tuesday, April 22, 2008 4:52:14 PM(UTC)
If there is nothing wrong with both water supply lines then the problem is a bad water inlet valve.
- The part number for the water inlet valve is AP3500345
