MAYTAG WASHER WILL NOT START. IT WILL SPIN OUT WATER .BUT WILL NOT FILL WITH WATER . MAKES HUMMING NOISE WHEN YOU PULL OUT KNOB.:confused:
If there is nothing wrong with both water supply lines then the problem is a bad water inlet valve. - The part number for the water inlet valve is AP3500345 Gene.
