alandlulu
#1 Posted : Tuesday, February 2, 2010 2:26:46 PM(UTC)
alandlulu
The original issue with the dryer was that it was overheating, hot to the touch and basically burning the clothes. I cleaned out the lint ducts, checked for blockages, changed the thermostats, checked for a short and can't figure out what the problem is. Now the heating coil comes on when I just turn the timer on, not even pushing start yet. It stays on until I manually turn it off. Any advice would be greatly appreciated.
#2 Posted : Wednesday, February 3, 2010 1:35:35 AM(UTC)
A model number may help others help you
Sounds like you have a grounded element.
Check the heating coil.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run on high and the thermostats cannot regulate it.
Often you can see the above with a visual inspection of the heating coil.
alandlulu
#3 Posted : Wednesday, February 3, 2010 2:12:09 PM(UTC)
alandlulu
Thanks for the reply. The problem was the coil. I had it checked for continuity and it was ok, but it had gotten so hot that it warped and was touching the dryer side of the case. I replaced it and is running ok for now.
