The original issue with the dryer was that it was overheating, hot to the touch and basically burning the clothes. I cleaned out the lint ducts, checked for blockages, changed the thermostats, checked for a short and can't figure out what the problem is. Now the heating coil comes on when I just turn the timer on, not even pushing start yet. It stays on until I manually turn it off. Any advice would be greatly appreciated.
A model number may help others help you
Sounds like you have a grounded element.
Check the heating coil. Unplug the unit and both wires to the coil. Check it with a meter, should be around 12 ohms. Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run on high and the thermostats cannot regulate it.
Often you can see the above with a visual inspection of the heating coil.
If you do not own a meter, I would suggest you purchase a one. You can get a decent digital multimeter for under $20.00. You do not need fancy though it is nice if the leads are a couple feet long. If it saves ordering one unnecessary part it has paid for itself and you end up owning a useful tool. Most places will not let you return electrical parts so if you order it, you own it. A couple things to watch when measuring ohms and continuity 1. Always remove power from the machine otherwise you could blow your meter. 2. Always disconnect at least one side of any device you are checking. This eliminates the possibility of measuring an alternate/parallel circuit path. 3. When checking for closed contacts and continuity use the lowest scale (Usually 200 ohms). Then try higher scales. This scale is 0 to 200 ohms so if the device you are measuring is 300 ohms this scale would show an open circuit which it is not, you are just measuring outside the scale's dynamic range.
There is a good STICKY at the start of this forum about it's use. |
THIS FORUM IS DEAD!!!!!!! |
Thanks for the reply. The problem was the coil. I had it checked for continuity and it was ok, but it had gotten so hot that it warped and was touching the dryer side of the case. I replaced it and is running ok for now.
