Need Help Replacing Wire Harness W/terminal Block
Have never worked on one of these but can supply you with a manual http://136.166.4.200/contents/Laundry/DLG2524/DLG2524_Service_Manual.pdfCannot see it as being a big problem just take your time. Make sure to make yourself lots of diagrams of where wires go. A digital camera can also be useful to document what goes where. Try to do it in stages rather than pulling everything off and then installing the new harness. |
THIS FORUM IS DEAD!!!!!!! |
