1938rock
#1 Posted : 11 years ago
1938rock
Hello, I'm hoping to get some help repairing my LG TROMM electric dryer.
I had just moved into a older home, and I needed to change the 4 prong power cord to a three prong power cord. I followed the instructions on rear of dryer to switch them. I turned the power on and started a normal load setting, and I began smelling smoke and pulled the plug. It only ran for 10 seconds.
I learned from an electrician that there had been a change to the wiring on the back and I needed to put the ground and neutral on same terminal. I did that and it works, but now it seems like it only gets warm and needs to be turned on several times for one load of laundry, which before moving it only took one cycle.
So I need help in how to determine what I need to do to fix this. Thanks
Scott
#2 Posted : 11 years ago
The most common cause of poor drying is a ventproblem so i would check that first.
Unplug the unit and disconnect it from the vent system.
Now try a run.
If it now dries OK odds are the vent system needs checking/cleaning.
Be sure to check that the louvers on the outside of the house open correctly.
If you do not want any lint in the house.
Take a pair of pantyhose.
Put one leg into the other and then attach this to the dryer's vent.
Leave enough room so the pantyhose can balloon out like a windsock.
Both the above will let you check the temperature and the air flow.
Note: The above is not recommended for gas dryers due to carbon monoxide concerns.
