woodzee61
#1 Posted : 17 years ago
woodzee61
The freezer side keeps frosting up.I have changed the defrost heater and the defrost thermostat. that did not work So i changed the main board/timer. that did not work either. I have tested everything again.
I have continuity at the heater and at the thermostat.froze or un froze.The heater looks like it has never been on. Were do I go from here.
Desperatly needs help The refrigerator is in the five to ten year range
GE Side by Side Refrigerator Model GSS25IYNXHFS dim LED lights (Refrigerator & Freezer Repair)
by jhauter 10 months ago
GE side by side turns on only when I disconnect J4 plug (Refrigerator & Freezer Repair)
by PandaTaco about a year ago
GE side by side water and ice not working (General Talk)
by Guest 2 years ago
GE Side by side fridge; control panel blank; not cooling (Refrigerator & Freezer Repair)
by peteror 3 years ago
GE side by side PSS26SGPA SS (Refrigerator & Freezer Repair)
by Guest 3 years ago
GE side by side clicks once by compressor then once on board. (Refrigerator & Freezer Repair)
by Schaanman 3 years ago
GE side by side model GSS25KSTASS ice maker auger continues to run (Refrigerator & Freezer Repair)
by RodneyS 4 years ago
GE Side by Side Freezer 25 degrees warmer than set-point (Refrigerator & Freezer Repair)
by reese600 4 years ago
GE side by side starts and stops (Refrigerator & Freezer Repair)
by SethL 4 years ago
GE Side by Side - Water/Ice Dispense (Refrigerator & Freezer Repair)
by USS Pogy 4 years ago
GE Side by side GSHS6LGBBHSS (Refrigerator & Freezer Repair)
by Ksutherland 5 years ago
GE side by side refregator does not start (Refrigerator & Freezer Repair)
by patel_bhavesh100 5 years ago
GE side by side, uneven cooling (Refrigerator & Freezer Repair)
by GLMace 6 years ago
GE Side by Side Thermistor Locations (Refrigerator & Freezer Repair)
by AlkiRich 6 years ago
GE side by side, sporadic water and ice dispensing (Refrigerator & Freezer Repair)
by Ramski00 6 years ago
