I had to replace the water paddle that broke,When i took off the front cover the harness-ribbon cable that plugs into the board control from the power board came undone.I slide it back into the board control,and closed everything back up.When i plug the fridge back up the ice maker starts spitting out ice.I took every thing apart again to re-check it. it all seems to be plug in right.What of the 3 parts do you think i need?
